| S&S Swan Maintenance - Rhombus continued |
Posts: 243 |
Rhombus continued |
Mike It is suggested that you check whether there is a solid area without core under the fitting, and if so what size back-up plate fits in that area. If you drill holes for through-deck bolts the thickness of the solid laminate can be determined. With this information the load bearing capacity can be estimated. How far from the nearest bulkhead is this fitting? Best regards Lars |
