S&S Swan Maintenance - Haato Water Heater
04 October 2008 - 22:18
Haato Water Heater
Hello All,
looking for any suggestions to trouble shoot our recently dysfunctional Haato water heater.  It is the original (I believe) water heater in our S&S 47.  Having difficulty visualizing any specs from the unit, located under the nav station seat.  In fine working order one night, then not the next.  shore power on/off due to electrical outages on land in interim, but all other a/c powered bits are working...
jill
06 October 2008 - 20:32
Jill
One possible reason is air in the heater, the overheating protection will then cut off the power. To remove the air open a hot water faucet wide open for a moment.
If this does not help it is likely to be an electrical malfunction
07 October 2008 - 00:02
Professor
have opened faucet...to no avail.  owners manual seems to indicate there is a reset switch somewhere on the unit, but I cannot find it (nor the thermostat control it supposedly sits next to).  My next question is....should i just be glad the water heater lasted for nearly 30 years, and research new ones????  If yes... any feedback on good (and bad) choices much appreciated!!
Thanks!
jill
th
07 October 2008 - 18:39
Jill
You are right that the overheating protection may need to be reset, and it sits next to the thermostat.
First unplug the heater cable from the AC outlet
Then open the cover where the cable goes into the heater. Behind the cover the thermostat and protection are found, if tripped the latter is a small protruding pin which needs to be pushed back in.
Put back cover and plug in the heater cable into the AC outlet.
Did this help?
18 October 2008 - 22:17
YES!!!  this worked!  Thanks so much for the guidance, once I knew where to look (under a plate) it became so much easier.  15 minutes later, steaming hot water!
thanks again.
jill
