| S&S Swan General - Increasing the diesel tankage on Swan 47 |
Posts: 199 |
Increasing the diesel tankage on Swan 47 Dear Friends, 200 liter of diesel, or there about, seem a little on our 47, especially when planning to get her to the med in the summer of 2010 and perhaps even further. Thus, I am contemplating adding two additional diesel tanks. One idea would be to place one under each bunk in the forecabin, trying to place them as high as possible so that they can siphon down to the ordinary tanks under each side of the saloon bunks. This solution, although possible, would add weight in the front part of the boat. Perhaps not very good. This being said, there is not very much space elsewhere to dispose of. Questions: Please suggest solutions and improvements to this idea or other ideas altogether. Thankfully yours Philippe |
Posts: 243 |
Philippe
I agree that diesel tankage (and water as well) on our boats is rather scanty but I would discourage performing expensive and intrusive changes. Jerry-cans on the deck is a possibility but another is plastic bladders in the bilge. |
Posts: 36 |
One other option would be to spend the money on light air sails and sail handling :-) , though I'm not sure how the 47 performs in light winds. If you are going to build some additional tankage. The suggestion of another in line pump sounds good. It might be possible to isolate your new tanks so that you can switch between them independently using some y valves and decide which tanks the engine is sourcing from. Although if you install too far from engine you have to consider the existing fuel pumps ability to pull the fuel from the new tank if it is farther away. Just a thought. I'm planning on going with jerry cans and a manual hand pump for transferring the fuel from can to to tank for long voyages. (as trying to pour anything into a hole on a pitching deck can be difficult). My Swan 38 only has 110 liters of fuel :-( -Nathan (s/v Inspiration 38/090) |
Sorry but I do not agree on Y valves and a second tank on the fuel system. If, for any mistake, you get air in the system you are in trouble as we all know. |
Posts: 69 |
Hey Philippe: A previous owner added to the fuel tank storage on our Swan 47(048). Our two original tanks are port and starboard in the main salon and contain 27.5 gallons each. The 2 additional tanks are located in the aft cabin on the starboard (29 gals.) and port side (23 gals.). I have a meter on my nav panel indicating how full is each individual tank. There is a valve system forward of the engine (see pic) allowing me to select the desired tank. I have not used any other system for me to have a comparison, but this system is fine. Milo s/v The Last of the Normal People |
Posts: 199 |
Thank you Friends: Mike, Daniel, Nathan and Milo! All your advises and suggestions are taken into consideration thankfully. They are very wise indeed. May I make some comments? 1- Investing in light air sails and handling is already done. What do you do when there is no air at all for days on end? The last summer, crossing over to Scotland from Scagen in Denmark, we had a 36 hours with no wind. We motored very econimically and we had barely enough to reach port. 2- Jerry cans and hand pumps: probably the most reasonable but, alas, perhaps not very esthetically appealing. I still will consider the possibility. 3- Adding two extra tanks has been obviously done on Milo's 47 in the aft cabin. This souds as an attractive option. Better aft of course than in the forcabin as I thought at first. However, there is more space there under the bunks: a huge space. 4- Air problem: Indded, it is a matter to take seriously. My idea, if I go for two extra tanks aft, would be to place then higher than the existing one - which are situated on port and starbord sides in the saloon. I will then connect the aft port tank to the port tank saloon and the same with starbord pair. The result would be that when filling the aft tanks the diesel will flow first to the saloon tanks, being lower. When the saloon tanks are full, then the aft tanks start filling...as if they were the same tanks (two by two) with a connecting pipe between each pair. I presume that I might avoid the air problem in this way. Would I not? Lars, am I missing something here concernin the air issue? 5- For many reason, I have this fix idea that I badly need more diesel capacity. I would have loved to increase it to, say 4-500 liter. AS to the water capacity, I am planning to invest in a water maker! Million thanks to all for your insight. Cheers/Philippe |
Philippe About adding tanks aft. In order for the fuel to flow properly from the saloon tanks to the aft ones the connection needs to have the same dimension as the filler line from deck. Assume this is rather impractical, and it would be advisable to have an own filler line from deck/cockpit aft branched to each tank. Then the connection forward can be the same size as the feed line. Milo may have such an arrangement? Vent lines for the aft tanks are also needed. Here a few more comments about these matters: Fuel capacity and range under power The range under power is very much dependent on the speed used. Here some rough guidelines for the fuel consumption in calm conditions. Yacht size at 4 knots at 5 knots at 6 knots at 7 knots at 8 knots Up to 44 ft 1.5 ltrs/hour 2 ltrs/hour 2.8 ltrs/hour 45 to 60 ft 2.3 3.3 5.3 ltrs/hour Over 60 ft 5 6.5 8.4 11 ltrs/hour These numbers are affected by the propeller type and dimensions. Does somebody need the numbers converted to US gallons? Check if there is a Speed - Consumption - Range diagram onboard, it shows measured data for the original installation. If the engine has been replaced the diagram does not refer any more. Use of fuel tanks In case there is more than one fuel tank it is advisable to use only one tank at a time, and direct the fuel return to the same tank. If the fuel return is directed to another tank which is full or nearly full this may make it overflow through the vent line. If two tanks on opposite sides are in use at the same time, and the yacht heels, fuel will drain from the high tank into the low one, which may overfill. As a result the fuel feed line will suck air from the empty tank although the other tank may be full. This gravity feed effect can be used to move fuel from a windward tank to a leeward one, just open the connection when the yacht heels. If the engine is run while the yacht heels, it is advisable to use the windward fuel tank if there is a choice. The tanks normally have sloping bottoms with the fuel suction at the lowest point, and in the windward tank there is less risk of sucking air as the fuel level over the suction in heeled condition is higher than in the leeward tank. Lars |
Posts: 73 |
De\ar Philippe
Posts: 199 |
Dear all, dear Lars and Sergio, Thank you so much for your valuable insights. All points are taken. Sergio, there is very littel space around the steering arrangement. I was thinking of placing the additional tanks under the aft berths port and starbord. Lars, The flow of the fuel will have to go from aft to the regular tanks in the salon. Not the other way around. In that way these aft tanks will act as fixed jerrycans (Sergio), whilst the ordinary ones will continues to act and function as they do know: excellently without any air problems and so on. An arrangement with own feed line, own vent to the aft tanks as well as a connection to the regular tansk will be done as per your kind instructions. That is if I go for this project at all. Lars, as you know, I have a new engine and I did benefit from many advises from you, including the excellent fuel consumption data sheet that you provided me with. I include it here as a pic. You will all notice how little ca. 200 liter of fuel are in certain conditions, such as those encountered in the north sea with adverse currents and tides, with no wind or "wrong" winds, etc. Thankfully yours philippe ![]() |
Beautiful graph! I wonder if I could have a similar one for any of the S&S 411. I was not so lucky to inherit one among the documentation of my hull (411-004) which was, otherwise, quite complete. |
Posts: 199 |
Daniel, I am sure that you can. You will need this: 1-Boat data, engine HP, Reduction ration, Propeller type and size. 2- You need to record 4-5 runs in relative calm and deep water (deeper that 15-20 meters) at different RPM, each time recording the speed when stabilised. exemple: at 1000RPM= X knots; 1500= X1 Knots etc.. Choose sensible intervals that make sense. With that you can plot the data and get your graph. Perhaps Lars could advise. Cheers/Philippe |
Philippe, |
Posts: 199 |
Daniel, Obviously there are known variables and those that are worked out with algoritm. The known variables are your engine consumption at different RPM. Other variables are the hull's flow though the water given all the other variables as mentioned in the last message. The calculus intervenes to determine the right ratios between the known variables. Lars might have data for your hull. All in all, the figures cannot be expected to be 100% accurate, but they do give a fair indication. Cheers/Philippe
Posts: 126 |
Dear Friends, 200 liter of diesel, or there about, seem a little on our 47, especially when planning to get her to the med in the summer of 2010 and perhaps even further. Thus, I am contemplating adding two additional diesel tanks. One idea would be to place one under each bunk in the forecabin, trying to place them as high as possible so that they can siphon down to the ordinary tanks under each side of the saloon bunks. This solution, although possible, would add weight in the front part of the boat. Perhaps not very good. This being said, there is not very much space elsewhere to dispose of. Questions: Please suggest solutions and improvements to this idea or other ideas altogether. Thankfully yours Philippe Phillipe, I have a Swan 47 centreboard called BLACK TIE and we have larger tanks which I think were fitted by Nautor. Our fuel capacity is 400 litres and water is 600 litres. The largest fuel tank is in the bottom half of the hanging locker opposite the heads forward, with the other much smaller tank under the after end of the port settee. This arrangement seems to work well and isn't quite as far forwards as you were suggesting. Gavin |
Posts: 199 |
Thank you Gavin, I am impressed by your capacity in fuel and water. I wonder why Nautor did not do it in all the 47!? Anyway, I will look at the locations that you mention. I will let you know. Cheers/Philippe |
