| S&S Swan Maintenance - How to Make B&G Analog Displays Moisture-Proof |
Posts: 43 |
How to Make B&G Analog Displays Moisture-Proof Hello All; Can anyone help me figure out how to make B&G analog displays moisture-proof? I replaced the glass to face plate O rings with 1mm dia and the backing plate to glass O rings with 2mm diameter and liberally applied high-vacuum silica grease to them before reassembly. I then put a bead of silicone sealant around the perimeter of the backing plates before remounting them. They fogged up the next day! Are the O rings I'm using too small in diameter, or is this the best I can expect from B&G? Please bear ing mind that I want to be able to reopen them in the event they need servicing in the future. Thanks John
I am sorry but right now I cannot tell you anything on the thickness of the O-rings because I do not have them close to where I live but I can comment on the rest. |
Daniel is right about the moisture content of air, but B&G used to put small bags with desiccant inside. These bags absorb moisture, and can be dried in an oven before put back in. Lars |
Posts: 43 |
Daniel & Professor; Thanks for your observations. Perhaps adding additional bags of silica gel is a good idea. I tool the precaustion of heating the entire display to about 50 deg C before sealing them to ensure they were dry inside. Today, I resealed the front and back O rings with silicone (my least favourite sealant). I'll let you know if anything improves. Much obliged. John |
Dear John, |
John, |
Posts: 43 |
Daniel; Got it. Thanks. John |
Posts: 203 |
Hi everyone. Its really very nice to exchange recepies about our dear Swan mistresses! On that one, may I confess that after different tries and failures we just leave the displays open, IE without the original dessication caps. So they can really breathe whatever air comes. No more condensation! Up to now it has been working fine for at least the last 15 years... I suppose it might no be OK for other climates than the Med. Kind regards. Philippe 41/022
