| S&S Swan Maintenance - 38 Shaft Strut Corrosion |
Posts: 11 |
Jim, |
Jim The strut should not corrode, and there is some particular reason for this problem. If there is a cable connected to the inside of the strut it is likely that the corrosion is caused by an electrical leak on board. Disconnecting the cable will stop the corrosion, but then some other underwater part may suffer instead, and it would be preferable to find the leak and eliminate it. Are you connected to shore power? Is there a zinc on the propeller or shaft, and how long does it last? Daniele, afraid that a zinc on the strut will not protect the propeller, because electrical contact between them is required to form the protective circuit. The shaft rubber bearing prevents this contact Kind regards Lars |
Dear Lars, |
Posts: 2 |
Hello
