| S&S Swan General - life rafts |
Posts: 252 |
life rafts I am seeking ideas on best way to stow life raft on Swan 411 - on deck can cluttter her clean look, the previous owner put the raft in the cockpit, but that sacrifices the stbd seat in the cockpit, so it's not ideal either. I wonder if anyone else has found a creative workable solution? Thanks, Geoff |
Posts: 41 |
the best Life Raft solution i have found has been the: VIKING, 6 persons RescYou™ Pro, which fits in the cockpit life raft locker (without the extra food and water required for off shore, which I keep in a special ditch bag in the main cabin with other necessary ditch items), a presto Pippo /411 Naomi |
Posts: 252 |
I am assuming the cockpit locker is under the stbd seat? The previous owner of my boat tossed the seat cover away, and stowed the Switlik there with hydrostatic release. I wondered about the nice half round receivers at the base, just like it was meant for a raft - I guess it was! Problem in my case is the raft is too big, so the cover wouldn't go on over it. I want to replace the cover, which if I do that, I will look at the raft you recommend. For the moment, I will keep the Switlik and work to get the cover made, then maybe in the spring switch it all over - Thanks for the help and your post, I appreciate it. |
