| S&S Swan Maintenance - Adjustable Genoa Cars what load for a Swan 40 ??? Professor |
Posts: 243 |
Mike The given working load is OK unless you have extremely powerful winches used to full capacity. I believe the size is determined by the width of your genoa tracks, which should be 1 1/4 inch. Kind regards Lars |
Posts: 5 |
Hello Mike,
After all these years, are you satisfied with your Garhauer genoa cars?
Michel |
Posts: 243 |
Absolutely!! Adjusting the genoa/ jib is easy now under load rather than adjusting the windward car then tacking trimming and ... hoping you got it right.. So easy to fine tune the car position!!!
I recommend it. I had to have the tracks trimmed so the car would slide freely... you need to remove the track take to a machine shop for them to trim then reinstall on the boat. This was relatively simple. --- relatively (;-)
Best
Posts: 5 |
Thanks Mike! That sounds like a great upgrade, but it's a pity you had to modify the track. My rail is 32mm wide and 6mm thick, so I'll see if I can find a slider that fits natively without needing a machine shop. Have a good day,
Michel |
Posts: 2 |
FYI I am using the Garhauer E-Z Glide Adjustable Genoa Car System G-3 on an original Lewmar 32mm track. I did not need to have the tracks machined, everything works very smoothly. However, i did specify all the dimensions of the track when ordering. As far as i understand the acetal sliders in the genoa cars can be adjusted according to the track specifications. The only minor gripe i have about Garhauer equipment is that some of the parts i've bought over the years have not been properly passivized and polished. |
Posts: 2 |
I am in the process of refitting Yankee Boy (411/016), including installing new high-load genoa cars for the forward and aft tracks. We have spent a lot of time considering the options and hardware. The setup will be as follows:
The car on the forward track will be daisy-chained to the forward car on the aft track, which will in turn be connected to the aftmost car. We will need a shock cord arrangement between each pair of cars. On hardware:
The conclusion is that we will be utilizing Ronstan here with the ball-bearing upgrades. The work will obvious require significant deck work and reinforcement to faciltiate the new track locations to facilitate a modern sail plan. |
