| S&S Swan Maintenance - 1973 S&S Swan 44 Cutlass Bearing |
Posts: 7 |
Dear Norman It is suggested that you measure the precise shaft diameter. If 30.0 mm, 1.181", it is original, and then I can give the bearing dimensions, otherwise not. Kind regards Lars |
Posts: 19 |
I have just had this done on my 44 and can get the dimensions from her. The issue was the rubber had come free from the outer housing at one end and was acting like a rubber tube to grip and release the shaft. Horrid vibration worse in reverse.
