S&S Swan Maintenance - 411 broken mast
06 June 2010 - 12:39
411 broken mast
I have recently bougth a Swan 411 to restore. During transportation the mast broke. Has anybody experience on repairing a broken mast?. do you know what alloy and treatment the mas have? (my 411 is one of the latest ). hanks. David.
07 June 2010 - 11:19
Dalonso
A broken mast can be repaired by a sleeved and screwed splice, like the one halfway up the mast, or alternatively by welding. This also depends on the damage. If you can find another upper or lower part from some earlier accident it just needs to be spliced in.
The difficulty with welding is that the mast is not necessarily straight after welding is finished, and the weld will be visible unless the mast is painted. The welder needs to have experience of such work.
The mast section alloy corresponds to 6061 T6.
10 October 2010 - 23:01
Dear professor, thank you very much for your reply which has helped me a lot as well as all the threads on the forum.
Kind regards, David.
