| S&S Swan Maintenance - AIS |
Posts: 199 |
AIS Hello out there, Cheers/Philippe |
Posts: 199 |
Hello Daniel, Thank you for a nice and well informed answer. While posting my question, I have discussed the issue elsewhere and the verdict is very much the same as your conclusion. The AIS antenna should be a dedicated one with aspecific span of about 161, 975 and 162, 025 Mhz. The VHF antenna is far too wide and, in addition to that, there is the problem related to the splitter sharing the occasional high voltage, as you rightfully explained. My conclusion: I'll go for a dedicatd antenna. Perhaps fitted aft or perhaps on the masttop. I will try it aft first and see. If it is as you say, that the AIS data flowing through the antenna does not need to be fitted high on the top of the mast, then I will be happy to avoid the extra work. The AIS engine I have ordered is the Two Channel AIS Receiver "EASY AIS. It cost ? 250 and it seems to be an excellent piece of quipment, far ahead of the cheap NASA. look at this link for details: http://www.yachtbits.com/ais/ My displaying possibilities of the AIS data will be taken care of by Maxsea (an excellent software by the way) on the laptop and its repeater in the cockpit. Cheers and fair winds Philippe//S/Y Farouche Swan 47 |
Hi, thank you for the information. The receiver you have chosen appears to be very good indeed (possibly the best for its price) but I am not sure if it is a truly two parallel channel listener. Maybe the two channels are fast duplexed so that they are practically monitored in parallel but I am not sure. Anyway, I believe that this is a very good choice and it will be soon in my shopping list too...
Posts: 102 |
Hello out there, Cheers/Philippe hello Philippe,
Posts: 41 |
Philippe, I have a Trueheading AIS receiver and transmitter installed on a stern mounted radar dome pole. We tested it in a storm in the Baltic last summer and It is incredible. As it was explained to me, you can put a splitter on an AIS receiver but not on a transmitter. You can't put the AIS antenna near your VHF antenna and the tops of masts are not installation platforms with extensive space. I was also concerned about having that maximum range. In fact, the installation we did, under 4m above the waterline turned out to pick up ships way over of the calculated range (about 15M). I felt much safer with the AIS than with radar, though one must not forget that there are a lot potentially dangerous boats that are not required to carry AIS. a presto Pippo |
