| S&S Swan General - Earthing |
Posts: 234 |
Earthing Can anybody explain why we have three earthing straps on my 411. One runs from the mast step to the keel, another from the backstay and a third from the stem head fitting. Do we need all of these? John
John, |
Dear John Are they round cables or flat straps? The standard arrangement comprises cables from headstay, backstay, main shrouds, and mast connected to the keel, and this is the lightning protection system. Flat copper straps are used for radio grounding purposes. Kind regards Lars |
Posts: 234 |
Lars / Daniele, The cable from the mast to the keel was clearly lightening protection but the rest I was not sure of. Do we need all the rest ? If so, I would like to replace a couple of them as they are in poor condition and have several joints which would be a weakness, what size cable do you recomend? My engine is also earthed to the through hull stern tube is this correct? Thanks |
John Thank you for the information The recommendation is to connect the lightning protection items mentioned above to the keel with 25 sq.mm cable. This set-up provides a Faraday's cage for the crew. The original engine had a two-pole insulated return electrical system, where battery negative was not connected to the engine block. It is suggested that it is checked whether the engine system is still insulated. It is possible that it has been modified, this happens on most older yachts when new equipment is installed. If battery negative is now in the engine block it would be advisable to disconnect the stern tube cable, and install an electrically isolating coupling between engine and propeller shaft if there is not one already Kind regards Lars |
Hi Lars, |
Dear Daniel Referring to your questions 1) I would suggest that originally battery negative was not connected to ground, but nowadays there are standards prescribing this. If you have the original electrical schemes this can be checked. 2) Engine and tanks are masses of metal and could therefore be connected to ground as part of the the lightning protection system in order to prevent side flashes. There are arguments for and against the bonding of seacocks and other underwater fittings. Particularly in the USA bonding is common, but it can be pointed out that ABYC standards also contain chapters dealing with unbonded installations. Older Swans do not have bonding 3) Shore ground should be connected to the boat ground, i.e. to the water. The shore ground often carries a small voltage which causes corrosion on underwater fittings. A protection is recommended, either a galvanic isolator, or the transformer you mention. Afraid that there is not one single best solution for all cases There are various standards for electrical systems, and they have usually been developed based on what should and should not happen when things go wrong. Different ideas are proposed, and the standards may therefore differ in some respects, Best regards Lars |
Posts: 53 |
Hello Daniel
Posts: 68 |
Dear Lars. I am currently completing an engine replacement on Hierro. I have not replaced the earth cable from the lightning grounding system to the engine block,as the new engine has a single wire 12volt system. The shaft has an insulated coupling. thus the anode is only protecting the shaft and propellor. There is a grounding cable from the steering quadrant,to the stern tube (which appears to be original). thus bonding the stainless rudder shaft and the stern tube to the lightning system, is this how it was originally designed? also the lightning system is connected to the keel via a bolt on the lifting eye in the bilge , is this as original? Many Thanks Paul 411 042 |
Dear Paul Thank you for your message. The recommendation is to remove the wire between the quadrant and the stern tube, and particularly check that there is not an electrical leak from the autopilot (then usually with rotary drive) through the steering system into the water. If the electrical schemes are still on board you could have a look at the original set up, but the non-insulated engine is likely to upset this. I do not have on record to which keel bolt the lightning protection usually was connected, perhaps other owners could take a look and let us know? Kind regards Lars |
Lars and Paul, |
Posts: 234 |
Lars, several years ago I fitted an SSB radio, so have twin isolaters on my backstay. I still have the earthing cable fixed onto the backstay. This to my mind is now not working because of the isolaters, so it is not required. Is this correct? The SSB is has its own independant grounding plate. Interestingly the backstay earthing cable was grounded to the stainless steel P Bracket. On the same fixing was yet another earthing cable going forward to the grounding bolt of the propshaft through hull tube. The engine earthing was also fixed to this propshaft tube. So as I understand if we got hit by a lightening bolt which went down the backstay, the charge would have got through to my engine. This seems crazy wiring. The engine should be grounded to something seperate from the Faraday cage. Is this correct? |
John You are right, with an insulated backstay the lightning protection cable from the backstay is not required, Large metal masses like the engine, depending on the electrical system, could be connected to the lightning protection system, but with a separate cable not incorporating other items, and the stays have their own cables led as straight as possible to the keel. As suggested earlier on this forum, it is likely that your engine block now is connected to the battery negative. The battery negative may or may not be grounded, depending on which standard was used for the installation. In the latter case the engine has a connection to the keel. Would suggest that the cables to the P bracket and stern tube can be removed Kind regards Lars |
Posts: 234 |
Lars / Daniele. Battery negative is not wired to engine block. Perkins M65 engine is still wired as two pole insulated return, but has a relay on the starter motor which changes system, but just when cranking the engine. So I have rewired the earthing to the stern tube and P Bracket, but not continued to rudder shaft. Hope this is now right? The Fraday cage wiring is attached to a plate which fits over the two keel bolts just aft of the mast, as shown in photos. |
