| S&S Swan General - Water Maker,self steer, power |
Posts: 252 |
Dear Geoff, |
Posts: 252 |
[EPIRB.....not EPRIB, sorry for the typos in my original post] Further to that point, sat phone v SSB and EPIRB, does anyone know sat phone approximate cost to install and run? As for SSB on a north Atlantic crossing, I would assume one could always be in contact with a land station, if coming out of Rhode Island and taking more or less a great circle east, up and just under Newfoundland....so, what would the sat phone do for us, if anything (I can just see spending thousands so my sons can sat-txt their girl friends...man!). Any input appreciated, and thanks, |
Posts: 177 |
Hi Geoff,
the equipment may depend on what will happen later. Are you planning on a single ocean crossing (maybe with a return trip), or will multiple crossings follow? Personally I think that for a single trip you can easily improvise.
Posts: 234 |
Geoff, I am hoping to set off this year on a long trip and have been setting up my 411 for some time. Hydrovane fitted, very good piece equipment. Fitted Iridium Sat phone linked to laptop with Seapro charting software so can download grib files onto charts. SSB fitted because its use is free once installed unlike Sat phone. Certain parts of the world operate very good radio networks especially in the W Indies. I can also down load weather info via SSB to laptop with special software. Old technology is not always bad technology! Just about to fit water maker. I am going for Dessalator. 60 lt per hour to fit with number of people planned to be on board and my battery charging regime. This should be your main critieria in choosing size required. Particularly this model operates at a stable pressure, unlike energy recovery machines. So the membranes last longer. www.dessalator.com The design and technolgy is also well proven i.e. not the latest or newest, with a good dealer network across the world.
Posts: 243 |
HI All, |
Posts: 83 |
Dear Geoff, I have just fitted a wind vane steering to my 41. The type is Neptune, made in the UK, and about half the price of the Windpilot. I have chosen a servo pendulum as it can be removed by releasing one bolt. The servo rudder can be swung up out of the water when motoring. I had a hydrovane on my last boat, and found that the rudder vibrated so badly in the propellor wash that the unit kept breaking the locking pin. This is a little known problem with a fixed rudder type, but can be a real problem. It obviously depends upon the propellor position and may be OK on the 411. The Neptune unit seems well made with very strong castings, but only time will tell as to its effectiveness. The mounting bracket fitted with 4 bolts either side of the backstay knee, I was amazed at the thickness of the transom at this point, there is clearly no problem with the strength of the mounting. With the windvane removed, the existing swim ladder can still be used. regards Cosmo Little (Trinket)
Posts: 252 |
Martin, John, Mike and Cosmo - and Matteo -
