| S&S Swan General - Single point lifting |
Posts: 68 |
Single point lifting We have recently launched Hierro from a boatyard, where unfortunately the boats need to be lifted from the travelling hoist, to the water, by crane.The complications of transferring slings, positioning the lifting frame etc. are not good for my stress levels, so apart from changing boatyards the option of using the single point lifting eye fitted to the 411 seemed worth investigating. Has anyone used this method of lifting any of the S&S boats? I am interested in the arrangement of the lifting strop to the crane hook and how the yacht balances fore and aft, does any extra weight such as anchor chain up foward need to be removed prior to lifting? Any advice or tips from practical experience would be appreciated. regards Paul 411-042 |
Posts: 252 |
Paul: |
Dear Paul and Geoff
Dear All, ![]() |
Posts: 73 |
Matteo,
Dear Sergio, |
Dear Sergio, ![]() |
Posts: 68 |
Dear All. thanks for the advice. I will check with our local lifting equipment supplier for the correct size of wire sling and joining shackles, before discussing the option with the boatyard. If I use this system I will report back, which may be of interest to others. thanks again. Paul 411-042 |
Posts: 5 |
Single point lifting Dear all Use this method to take her up and found it easy and reliable. Have a frame as Lars mentioned to balanse her. Regards Hĺkan 38/57 Arajata |
Posts: 68 |
Hakan. Thank you for the photos, I note you are using nylon webbing slings for lifting. I had come to the same conclusion that these were more suitable than wire strops. You show the boat being lifted without the rig, have you lifted with the mast in place? I assumed that the single point was on the centre of gravity of the hull and rig, I wonder if Lars can confirm whether boat will balance with the mast in place, or whether it is designed to lift the hull only? Regards Paul, 411-042 |
Dear Paul, |
Posts: 5 |
Paul No I always lift the boat without rig so I compensate that weight by moving the centre about 100 mm backwards with a piece of wood (as you can see on the photo, there is a larger piece of wood in the frame on the front side of the hatch). Regards Hĺkan 38/57 |
