| S&S Swan Maintenance - Lewmar 65ST primaries |
Posts: 3 |
Lewmar 65ST primaries On our Swan 55 yawl the teeth of our primary genoa winches are quite worn, causing the Genoa sheets to slip - does any one have an idea of a source for spare parts for these winches? Lewmar themselves do not list parts for these older winches. Many thanks Sam van Holthe Swan Valhalla
Posts: 18 |
look here www.winchspares.com |
Posts: 102 |
Hi Rikys, |
Sam It is suggested you check that the small pinion wheel driving against the inside of the drum is located at the point where the sheet meets the drum. This has significance at high loads, with wrong position the drum tends to deform, and the pinion may slip.
