| S&S Swan Maintenance - Garboard drain plug |
Posts: 396 |
Garboard drain plug Hi all, My boat, Mabel's Casse Tete, Swan 43 hull 003 came to me with a badly installed garboard drainplug; e.g., hole substantially larger than the OD of the plug fitting and 5200 used as filling material. So, I have a hole at the low point of my bilge, which has come in handy, but I will not reinstall the drain plug I have; it's a cheaper model that has a realatively small flange and the head sticks out 3/8 inch. The best I have seen is the Buck Algonquin garboard drain plug. http://store.hamiltonmarine.com/browse.cfm/plug-drain-1.00-pl-brz-1-socket-wrench-type-103383-/4,2236.html Does anyone have thoughts about: garboard drain plugs in general; which one is best; and safe installation? Thanks, Chris |
