| S&S Swan Maintenance - Propeller advice Swan 44 75HP engine |
Posts: 8 |
Propeller advice Swan 44 75HP engine Questar is a 1975 Swan 44 and was re-engined with a Volvo Penta D2-75 by a previous owner. Unfortunately the 16"diameter * 12" pitch 3-blade propeller seems to be unchanged from the original much-smaller engine, so the big engine revs away without much forward motion! I want to install a new fixed-blade propeller, but there is very limited hull clearance for a larger prop. I could just about squeeze in an 18" diameter prop if I grind a bit of the hull away. Even an 18" propeller seems very small and presumably will require a very course pitch to generate enough power. Shaft is 28mm diameter. Gearbox is 2.27:1 Does anyone have any similar experience / advice / solutions? |
Dear Simon |
Dear Simon |
