| S&S Swan General - S&S Swan Figures of Merit |
Posts: 46 |
S&S Swan Figures of Merit ![]() |
Posts: 199 |
I am interested to learn about the Sparkman and Stephens design philosophy that played out in the late 70s and 80s as it was applied to the Nautor Swans. Also (and more specifically), how my model 431 fits in this background. This site offers lots of quantitative information about the various models. Using the data from here and from other sites on the web, I have summarized the basic Figures of Merit for the S&S Swans (see attached table). I have included the number built (NBuilt) just for interest. I will take this information, calculate some basic performance and stability metrics and then perform some multivariate analyses which show how the various models compare to each other. It should be enlightening and I hope spark some lively debate here. I ask first that the group give some feedback about the initial Figures of Merit table. Please check your model. Have I summarized the information correctly? Getting the original information correct is important. I seek your assistance. Thank you, Kendall Hello Kendall, Answering your inquiry, I would say that the data for the 47 is correct. Perhaps you want to include the data for the 47 centerboard version. Furthermore, it would be nice to have the figures in both feet and inches but also in metric. Please find hereunder the details for the Swan 47. LOA 14.47 m (47.80') - LWL 11.05 m (36.24') - Beam 4.19 m (13.76') - Draft 2.40 m (7.8') - Displacement 14700 kg (32400 lbs) - Ballast 7000 kg ( 15500 lbs) - I 18.90 m (62.0') - J 6.04 m (19.8') - P 16.98 m (55.7') - E 4.88 m (16.0') - Fore triangle 57.0 m2 (613.8 sq.ft) - Mainsail 41.4 m2 (445.6 sq.ft) - 150% genoa 85.5 m2 (920.7 sq.ft) - Spinnaker 205 m2 (2210 sq.ft) - Mast top above water I + 1.45 m (4.8') - Antifouled area ( is this the same as wet area?) 47 m2 (59´06 sq.ft) Center board version: Displacement 15500 kg (341000 lbs) - Ballast 7800 kg (17200 lbs) - Draft 1.8/2.9 m ( 5.9'/9.5') - I am looking forward to your factor analysis. A well done such an analysis can be a very powerful comparative tool. Cheers Philippe (47/050 Farouche) |
Posts: 56 |
Dear Kendall, As far as I know, Swan 38's were built using three different sizes of rig. I think the most common is the standard tall rig. At least one (Infant, hull n: 014) was equipped with the special standard tall rig. Special standard tall rig Standard tall rig Standard rig Looking forward to your results! Jyrki |
Posts: 46 |
Thank you for your feedback Philippe and Jyrki.
Kendall, |
Posts: 46 |
Daniel - it will be interesting to me to see the effect of the 411 changes you mentioned. So, I added another line in the table for the draft modified 411 model. Please help me out though, was this done without changing the total displacement?
Posts: 46 |
I have run across the following seven metrics that can be calculated from the parameters in the Figure of Merit (FoM) table we have put together so far. I have loosely grouped them into Performance and Stability categories. Stability is really a bit complicated I gather and deriving something meaningful might require more variables than we have in the FoM tables. It seems that Beam at waterline would be helpful but I think it might take hull drawings to accurately get this information for each boat.
Kendall Suggest you add Sail Area/Wetted Area ratio, and a stability criterion, for example the Dellenbaugh Angle. For this you need righting moment information from rating certificates (available from US Sailing). In case you do not have such information I can dig it out. Other numbers which may be of interest are weight per immersion and moment to change trim It should be noted in connection with these calculations that waterline length, displacement, wetted area, and stability are not exactly the same for individual boats of the same model, if possible use average numbers. Kind regards Lars |
Posts: 36 |
The 41 also had different sized masts (a "short" and "tall" rig). I think the draft also may have changed a little along the way. |
Posts: 46 |
Lars and CBinRI, ![]() |
Posts: 199 |
Hello Kendall, I am looking forward to the progress and results of your efforts. I think that your project is brilliant. Thanks a lot Cheers Philippe (47/50 Farouche) |
Posts: 46 |
Philippe, |
Posts: 46 |
For reasons of merging some new parameters from available IMS certificates (which use metric measurements), Lars has suggested we carry along both Imperial and metric Figure of Merit tables. The first version of the new tables are below. ![]() |
Posts: 46 |
Reformatted for easier reading. Sorry for wasting some space. ![]() ![]() |
As I noticed few inconsistencies in the figures regarding the 411, I checked the original water lines drawing and found the true numbers. I extracted the enclosed legend given in imperial units. ![]() ![]() |
Daniele You make a very important observation in this connection, the numbers on the lines drawings are not the same as the numbers presented on this website. The difference is that the lines drawings show the design office numbers, and the website the actual as built numbers verified by the builder, or more precisely an average for several yachts, as extracted from rating certificates or weighing. It is common that the design and as built numbers differ, and a decision should be made at this stage regarding which alternative to use for the calculations. Best regards Lars
Posts: 126 |
For reasons of merging some new parameters from available IMS certificates (which use metric measurements), Lars has suggested we carry along both Imperial and metric Figure of Merit tables. The first version of the new tables are below. Kendal, thanks for your work on this table which is very interesting. I am always a bit suspicious about designer's displacement numbers. When I bought Black Tie my Swan 47 CB I had her IRC weighed on a single point crane with an RORC load cell and measurer. Almost everything had to be off the boat and the tanks emptied and the IRC number recorded was 17,770kg which is considerably more than the design numbers. I am not sure how this would apply to the other boats in the Swan range. I would be interested in the professor's perspective on this as I suspect that Nautor tended to overbuild their boats.
Dear Gavin Thank you for your information referring to Swan 47 CB version weight. This made me search for rating certificates. I found 12 MHS or IMS rating certificates, of these 5 are for centerboarders. These certificate displacements roughly fall into four groups. There are three 47:s with around 15.7 tons displacement, three around 16.4, two CB:s near 16.5, and three CB:s near 17.7 tons. The keel draught for one 16.4 t differs too much from the others, and the conclusion is that there is an error in this certificate. It is also strange that there are so big variations in the other displacements, although the draughts are rather similar, this could be the result of using different hull files for the calculations. Unless the boat carries internal ballast Gavin's reported RORC weight is considered correct and the basis for Swan 47 CB. The weight is consistent with the three CB:s above, but this means that the displacement given for the standard keel version is not correct. It is likely that the 14.7 ton on the Forum for the 47 originates from the IOR rating rule used those days, where the rule displacement was some 10 % smaller than the actual. 16.4 tons would then be a good estimate for the actual displacement with the standard keel, and the centerboard version displacement about 1.3 tons heavier. The difference consists of 0.8 ton heavier lead keel, the board weight 209 kg, plus the lifting arrangements. It would be good to check the weights for all models in connection with the Numbers of Merit excercise. Would appreciate very much if owners could supply certificate copies or verified weights, pls check your ship's papers, and send to Kendall or to me. There is also a possibility to determine displacement by calculation based on the accurate floatation provided either the trim screws or the original boot top are still there. (see under the S&S Swan Maintenance, all threads, Page 3, 15 February 2009 for information on this subject). If neither can be used another but less accurate possibility is to measure the height above water for the lower tip of the transom, and the stemhead. Preferably also indicate if the yacht is in ocean, fresh, or brackish water, as this has some influence on the results. Kind regards Lars |
Posts: 46 |
All, ![]() ![]() |
I expect that the study proposed by Kendall may become quite interesting but, following his initial invitation, I have a comment. |
Posts: 46 |
Daniel, |
